SS-V: 1070 Plate with a Hole
Test No. VS08 Find the maximum stress of a plate with a hole.
Definition
Due to symmetry, only ¼ section was analyzed (Figure 1).
The units are SI.
Sliding constraints applied to the left, back, and bottom faces.
The load is 5000N applied to the right face.*
The model parameters are:
Value
L
100mm
H
50mm
R
20mm
F
100N/mm2
Thickness
1mm
The material properties are:
Properties
Value
Modulus of Elasticity
2.1e+11
Poisson's Ratio
0.3
Results
The reference solution is given by:
σ m a x =   k σ n o m MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVCI8FfYJH8YrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbb a9q8WqFfeaY=biLkVcLq=JHqpepeea0=as0Fb9pgeaYRXxe9vr0=vr 0=vqpWqaaeaabiGaciaacaqabeaadaqaaqaaaOqaaabaaaaaaaaape Gaeq4Wdm3damaaBaaaleaapeGaamyBaiaadggacaWG4baapaqabaGc peGaeyypa0JaaiiOaiaadUgacqaHdpWCpaWaaSbaaSqaa8qacaWGUb Gaam4Baiaad2gaa8aabeaaaaa@4325@
With k = 3.
σ n o m =   F h h − r   =   166 ,   7 M P a MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVCI8FfYJH8YrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbb a9q8WqFfeaY=biLkVcLq=JHqpepeea0=as0Fb9pgeaYRXxe9vr0=vr 0=vqpWqaaeaabiGaciaacaqabeaadaqaaqaaaOqaaabaaaaaaaaape Gaeq4Wdm3damaaBaaaleaacaWGUbGaam4Baiaad2gaaeqaaOWdbiab g2da9iaacckacaWGgbWaaSaaaeaacaWGObaabaGaamiAaiabgkHiTi aadkhaaaGaaGPaVlabg2da9iaaykW7caaIXaGaaGOnaiaaiAdacaGG SaGaaGjbVlaaiEdacaWGnbGaamiuaiaadggaaaa@4D9E@
k =   3   −   3.13 d h   +   3.66 d h 2   − 1.53 d h 3   =   2.2357 MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVCI8FfYJH8YrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbb a9q8WqFfeaY=biLkVcLq=JHqpepeea0=as0Fb9pgeaYRXxe9vr0=vr 0=vqpWqaaeaabiGaciaacaqabeaadaqaaqaaaOqaaabaaaaaaaaape Gaam4Aaiabg2da9iaacckacaaIZaGaaGPaVlabgkHiTiaaykW7caaI ZaGaaiOlaiaaigdacaaIZaWaaeWaaeaadaWcaaqaaiaadsgaaeaaca WGObaaaaGaayjkaiaawMcaaiaaykW7cqGHRaWkcaaMc8UaaG4maiaa c6cacaaI2aGaaGOnamaabmaabaWaaSaaaeaacaWGKbaabaGaamiAaa aaaiaawIcacaGLPaaadaahaaWcbeqaaiaaikdaaaGccaaMc8UaeyOe I0IaaGymaiaac6cacaaI1aGaaG4mamaabmaabaWaaSaaaeaacaWGKb aabaGaamiAaaaaaiaawIcacaGLPaaadaahaaWcbeqaaiaaiodaaaGc caaMc8Uaeyypa0JaaGPaVlaaikdacaGGUaGaaGOmaiaaiodacaaI1a GaaG4naaaa@61C8@
σ max   =   372.7 M P a MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVCI8FfYJH8YrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbb a9q8WqFfeaY=biLkVcLq=JHqpepeea0=as0Fb9pgeaYRXxe9vr0=vr 0=vqpWqaaeaabiGaciaacaqabeaadaqaaqaaaOqaaiabeo8aZnaaBa aaleaaciGGTbGaaiyyaiaacIhaaeqaaOGaaGPaVlabg2da9iaaykW7 caaIZaGaaG4naiaaikdacaGGUaGaaG4naiaad2eacaWGqbGaamyyaa aa@450B@
The following table summarizes the maximum stress.
Theory SimSolid % Difference
Maximum Stress [MPa] 3.7270E+02 3.7746E+02 1.28%
*To determine the load: 100N/mm2 x 50mm x 1mm.
